Well you COULD make the transfer case manual, right? I mean it's a diff thing I realize.
Thanks Josh I see what you mean, if they work you didn't have to get out in the snow, if they don't work, you'd probably never want them again.
Thanks Shran I am wondering if they did wheel bearings would they have had to mess with what you are talking about and if they did then is it right. But I suspect they will have packed it. That's interesting but I see your point, if the only thing they have to do is turn a small distance sometimes then there's no reason for grease packing it would just impede things. I'll have to check that.
Thanks fastpakr. So 8.8 is about the beefiest I'd get w/out custom, right?
3.73 seems fine, 4.10 wasn't offered in that package and going the other direction to me would be wrong.
Went for short drive, Vicky liked it. Seats are like velour, you don't slide around in them. I floored it and got to 50 in about 5 seconds. Or so, I mean, it's not a sports car, but let's say you're going up an on ramp and trucks are coming it's nice to know you have a little pep. Brakes are awesome. Steering is tight. She said it rides way nicer than the B3. That's probably the 60k miles diff. Plus the XLT was a way better model. Tires don't seem to really make it much noisier; that's not a terribly aggressive treat on the RTX's.
Had coolant leak after I got home. There's a back story: at the dealer I saw coolant, I showed them. Here's their story. Somebody tried the truck before me. On the test drive the heater valve (the one in the engine bay) broke and it sprayed coolant all over the engine. There's a U-shaped crossmember (this is where you see it dripping out) and they kept saying not all the old coolant that sprayed out was out of there yet so it was just moving around. I said the side of the radiator seemed wet (I'm not seeing that now... yet). We went back and forth on that for a while finally I said you know what if the radiator is shot it doesn't look that hard to pull it so if I don't see tons of it coming out let's forget it for now.
I'd say about maybe 1/2 oz total I saw - drips. I'm going to try to see where it's coming from, that I haven't determined. I don't see the coolant level going down at any noticeable rate.
There was a coolant jug in the cargo box. That might tell me something.
Anyway where do leaks come from (assuming this is not old coolant) - hose connections, radiator itself, what else? Head gasket? That'd be bad - but there would be other symptoms I suspect. I bet it's something simple. It can't be a huge hole or the stuff would be spraying out of there at temp. So I'm kind of chasing that first because there should be zero coolant coming out it unless it was overfilled and it vented some.
Here's a couple pics - not horrible for 25 years old! Wiped some of the bugs off the chrome otherwise didn't even wash it yet.
