shields1973
- Feb 5, 2020
- 1
- 98038
- Ranger 4.0
Good morning! I hope everyone here is doing great. I have this 97 ranger 4 x 2 3.0 that I put a used transmission in. I didn't check one item before installing. Output shaft speed sensor on the tail of the trans the hole Is plugged. It's an electronic sensor with a spinning gear on the end that runs off the tail shaft. I found out I bought a newer trans and for that year the speed sensor was moved to the rear differential and the sensor is no longer the same. The transmission goes into gear but won't shift automatically I assume because the sensor isn't there. Looking for possible solutions. Could I pickup a newer rear end and sensor in the diff? Or should I rebuild the old trans? Or any other ideas greatly appreciated.
A little history... when the trans went out u was just about to the top of a hill when it's like the trans went into neutral and the rpm's just rev and trans won't go into gear. No problems prior to that day.
I appreciate any help you out can give!
Jon
Jon
