97 Dome Light Wont Turn On
3ncrypt3d
Indiana, US
2.3
Done light in my 97 won’t turn on. Shouldn’t matter, but it’s a 2.3 5 speed 2WD. Since I bought it, the dome light won’t turn on at all. The dimmer switch won’t activate it either. Are there any relays/fuses to check? Thanks.
8,372
1997, fuse #27 in cab fuse box is for dome light
Dome light looks to be Grounded at the bulb, so pull out the bulb and test for good ground.
There is a 5 pole relay for the Dome light, when this relay is OFF it passes 12v from the Dimmer to the Dome light when dimmer is turned all the way
When you open the door GEM module activates this relay and passes the 12v to the Dome light.
So the 3 things in common for no dome light are:
GROUND at the bulb
Fuse #27
Relay
But the relay doesn't need to be activated for the Dimmer wheel to turn on the bulb, but it is possible for a 5 pole relay to fail and not pass the 12v in either position on/off.
This relay is in Relay box 1 just above gas pedal area under the dash, there are a few relays in there, I don't have a diagram of which is which.
I didn't include bad bulb..............because I assume you have tested it already
3ncrypt3d
Indiana, US
2.3
Well, there’s no fuse at #27. What amperage is it? I just stuck a jumper wire there, and my lights worked! Only, now they don’t turn off. So now it’s the complete opposite issue.
8,372
1997 fuse #27 is 10amp
Could be Dimming module is broken so keeping dome light on, or could be one of the door switches or its wire
See if BOTH "Door Ajar" lights on the dash work, same switch is used for Dome light trigger
GEM activates Dome light when either door is opened
Door open switch is a Ground to the GEM, so no Ground is door Closed, Ground is door open
If the wire from either switch is shorted to a Ground then GEM will think door is open and will turn on dome light AND "Door Ajar" light on the dash
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Very common problem is the light switch pin in the door sticking (and is probably why the fuse got yanked).
Many report spraying WD-40 into the switch or latch area will get it working again. Others say it gums it up and makes it worse. YMMV.
(all mine have the more traditional door jamb switch)
http://therangerstation.com/tech_library/DoorContactPin.shtml
3ncrypt3d
Indiana, US
2.3
Well, I don’t have a door ajar light on the dash. Took out the cluster, and there’s nothing there for that. I actually have a ‘new’ dimmer switch from another ranger, but everything worked fine from that one.
Tried that, and it didn’t do anything. Do you know if you can see the physical switch on a 97, or is it all internal?
3ncrypt3d
Indiana, US
2.3
Just a follow ups. Finally fixed it. I sprayed some carb cleaner in the inside of the door, and closed it repeatedly for a minute or two. Then I sprayed some lubricant on it, did the same thing, and let it sit overnight. Finally, now it’s working again. Now the key doesn’t constantly ding either, which is really nice
8,372
Good work :icon_thumby:
Thanks for posting the fix
RedneckwithaRanger
Cleveland
Ford Ranger Xlt
This solved my problem. I think the last owner took it out on purpose. Thanks for the wealth of knowlege Ron.
