Swoopy
- Oct 21, 2013
- 0
- Mazda
Hello all.
1995 2.3L 478,000 miles! original motor (never opened) and rear brakes!
2 trannies, 1 replacement clutch and front rotors twice and pads several times.
Runs great for the miles, still got 23 mpg! Extended cab 2 WD 3.91s
Runs a little softer and nice until yesterday.
Started to miss then corrected drove home 10 miles.
Next day ran great then when warm after 8 miles happened again then restored for about 3 secs than back to missing. Drove 13 miles. Went for a test run later that night, cold and after warm less then 3 miles and it did not miss. Next day, 5 miles ran good (normal) and than miss returned.
Ya I know, I'll get the OMG, but only 1 timing belt change at 160K.
Changed the 02s air, fuel and fuel pump at 250K. many with air and oil changes.
plugs 3 times and new radiator.
It will run tight till it gets about 5 miles or so, warm, then misses.
I know the T-belt needs to be changed and perhaps the tensioner.
There is a clicking noise louder then normal at front valve cover. Could it be cam sensor ticking?
It sounds like loud values or perhaps a fuel injector clack?
If it were mechanical, it would be constant and not run good when cold?
I'm thinking, timing or a sensor? But timing how when it runs good cold?
Could it be a closed loop runs ok, than data input when warm and misses?
I'm perplexed. Cat may be full also with that many miles.
Well been reading here and there on this site and found great information, and more then a few nice trucks.
Truck served me well, no regrets.
Purchased a T-belt, can sensor, and water pump seemed like a good idea as the miles are high, but no issues.
Didn't run codes but will buy a OBDII tool.
Stumped. Any thoughts would be appreciated. New motor instead of repairs?
