94 Ranger with V8 302/306... I have some questions
redlinezl
Lancaster, Pa.
FORD
Monster 2.3L 4banger
1994 RANGER EXTENDED CAB SHORT BED 2WD WITH 5/6 DROP...
ok right now its a carbed set-up with a Mustang automatic aod trans which is shot. I just picked up a used c4 for free and its off getting rebuilt..
I'm being told running a c4 isnt going to be good for me to drive daily and highway travels, some people are saying get a manual vale body in the aod and have overdrive on a switch.. what do you think?
also the c4 is obvoiusly smaller, my ranger is and extended cab short bed.. what about trans mounts and driveshaft? currently the shaft looks to be 2 piece...
ADVICE?
redlinezl
Lancaster, Pa.
FORD
I'd also love eventually to make it 5spd, it still does have the pedal assembly, but all the hydrolic clutch parts were removed.. whats that require or can u some how get away with a mustang adjustable cable and adapt a quadrant to clutch pedal??
baddad457
18
Opelousas La.
As far as a C-4 goes, that depends on how far you have to drive everyday. There's nothing to mount a cable clutch to, you'll have to fab all that. Be easier to go back hydraulic. Just need the master cylinder and a pressure line to the slave.
redlinezl
Lancaster, Pa.
FORD
as everyone has told me i guess im getting my aod build with a manual valve body and overdrive on a toggle
redlinezl
Lancaster, Pa.
FORD
that seem right?
redlinezl
Lancaster, Pa.
FORD
anyone suggest anything?
alaskan155
6
washington
FORD
7.3l/4.0l
if you already got the pedal for a manual tranny and wanting a manual AOD, why not just intall a t-5 from a mustang or similar with a hydraulic clutch?
redlinezl
Lancaster, Pa.
FORD
i got a t-5 now can i usee m,y factory 4cyl hydrolic stuff?
baddad457
18
Opelousas La.
You can do it easily with an external slave cylinder setup for a T-5 bell. The Mustang vendors sell the kits.
redlinezl
Lancaster, Pa.
FORD
well point me in the cheapest and easiest way to get it done, parts.. #'s and all. i got less then a week to go to track lol
88mudder
waterford michigan
i run the AOD on my mild v8 ranger with the 302, i love the 4 speed and its smooth shifting if properly tuned.
