yes, you want to swap injectors and pistons, use your stock inake manifold (it matches the head, turbo intake manifolds won't, and the throttle body is in the same place), your stock fuel pump will handle that much boost without problem
what you will need is the computer from a turbo engine, the vane air flow meter for that ecm (there are two different ones) and the wiring connector to go to it.
wire in the VAM to your current wiring harness, there's wiring diagrams in the stickie at the top of this forum, more than likely the VAM will wire where your MAF goes now. if you use the '87-88 computer you will need to drill and tap your intake manifold for an air temp sensor so you will need to wire that in too (in the older ones the temp sensor is in the VAM)
the other things you will have to do is get a tee in your oil pressure sensor hole for the oil supply for the turbo, and drill and tap a hole in either the engine block just above the oil pan or in the oil pan above the oil level, also tee into your heater circuit for the coolant lines for the turbo (assuming you get a water cooled turbo)
