stx4.0
- Feb 24, 2008
- 1
- ford
I have a clean 94 explorer sport that developed an issue from sitting.I got in it last year to basically warm it up as I dont use it that often since its a backup vehicle and dont like to let them sit very long without running them.I got in it and it would turn over but not fire.I popped the hood and checked all the fuses and got back in and it fired so I ran it down the road and warmed it up and then parked it.Now its doing it again only this time it will not fire.I have checked all the fuses and switched out the fuel pump relay,bypassed the inertia switch and it still will not fire and the fuel pump itself is new.I checked the pigtail to the fuel pump and there is no power going to it.I also checked the coil pack and it is not throwing a spark for some reason so whatever it is controls both the spark and fuel pump.I did swap out the crank position sensor and the electronic control on the core support with no luck and it I also checked for codes from the computer and got nothing.Everything still works as far as the power windows,locks,wipers,radio and im pretty sure no varmits chewed any wiring so I am at a loss on where to look now?
