93 brodozer turbo coupe swap
dvmulisha
So this is where im at
93 ranger long bed single cab
already had t5 tranny
8.8 w/ 4.56 gearing trussed
custom leafpacks
33 bfgs
15'' centerlines
cobra brakes with 13'' slotted/drilled rotors
extended beams coilovers yada yada. so went and and bought a $500 monte carlo from auction which has turned out to be a great little car. so i can get to where i need to be for work and blew apart the truck in a couple hours .
had a 2.3 and what god awfully slow , I found a 86 t.c. got the complete motor , bellhousing new clutch/flywheel , rebuilt turbo and found out when i brought motor too machine shop that it had recently been gone through.
day i got it , picked it up in my monte carlo drove 160 miles to get from casa grande to phx
So i replaced all the gaskets , bearing had really no wear at all. journals and cylinder walls were gorgeous.
painted the motor
dvmulisha
set the motor in with no issues
i did stingers wiring swap and it all very straight forward. im aware this was a 86 but im using a la3 computer and big vam awaiting for it in mail actually.
this is my harness
basically where im at is dealing with the bap sensor wiring, i dont know where the stock map sensor for the ranger is and im pretty sure i dont have one soooooo i have to either wire from ecu which stinger actually told me which pins to do it.
anyone else have this issue?
I ordered a front mount intercooler from treadstone , 2.5 intercooler piping , la3 ,
any advise or pointers will be appreatied
Mightyfordranger
157
Ohio
2.9
3in
Clean your room before you criticise the world.
What's the deal with the stinger setup is it a whole stand alone ecm or is it just a kit to run the stock la3 ?? Or does is run over top the la3 to make it a more manageable ecm system??
redhurricane
Westminster, Colorado
2.3
the stinger pimp ecu is basically a megasquirt ecu built into the factory ecu box.
nesralyrrej
Arvada Crawlarado
4.0 s/c
Make it fast, Make it loud.
Ah, good ol 2.3 turbo. Fun stuff. My turbo ranger just put 523 to the wheels with this engine. I can probably help with most questions that you have. Let me know
redhurricane
2.3
How about some specs on how you hit 523WHP? I'm a few miles from you.
nesralyrrej
Arvada Crawlarado
4.0 s/c
Ported head ported intake custom tubular exhaust mani, big turbo, e-85 tune, 1000cc injectors, big cam, building another one looking to get close to 700. Where are you located?
4EyedTurd
4
Waco, Tx
2.3
Sounds legit Mike, better watch out.
redhurricane
2.3
Seeing the posts from the past on his build, I am finding it real hard to believe.
"Big turbo" LOL
Pic proof. and a dyno sheet as well.
nesralyrrej
Arvada Crawlarado
4.0 s/c
Big turbo is a holset hx35.
I'll get the dyno sheet in the next couple days lol, or if you're actually near me I'll gladly let you see it
nesralyrrej
Arvada Crawlarado
4.0 s/c
Head work done by heads by drew here in Denver, the Exhuast manifold was made by me and my friend, the Holset hx35 has been converted to single scroll and ported, 1000cc fic injectors low imp, cam is a boport 2.1, tune was done by me running a stinger pimp ecu stock length rods and pistons, just weisco forged and I beam rods.
nesralyrrej
Arvada Crawlarado
4.0 s/c
Clocked and ported intake is also by stinger
Nosgusta
Hey man what kind of turbo are you using and what rpm you start to get full boost.
nesralyrrej
Arvada Crawlarado
4.0 s/c
Couple posts after this you'll see I was using a holset hx35, I hit 22psi at 3700 rpm, since this post I changed my turbo to a precision 6262 and am hitting 22psi at 3100
Nosgusta
Hey , I am trying to make 700 hp on a 2.3 L . on a thunderbird Motor my concern is oil pressure . I like the turbo precision 6262 This is my email prietomk4@gmail.com send me some pics of you build truck and more info of what you did or going to do to get 700 hp I would really appreciate the help thank you
No members online now.
