- Nov 13, 2018
- Reaction score
- 4,465
- Location
- Canaan,NH
- Make / Model
- Ford Ranger
- Engine Type
- V8
- Engine Size
- 351
- Automatic
- 2WD / 4WD
- 2WD
- Total Drop
- 3"
- Tire Size
- 235/55R16
- My credo
- If you don't have time to do it right will you have time to do it over?
I replaced the manual steering box in my 93 2wd with a power unit to make driving with a 351 easier. The truck had dropped I beams. The manual pitman arm had a slight drop built into it and the power one is straight which puts the drag link closer to the front oil drain plug than I like on full right turns. Does anyone know if 2wd and 4wd pitman arm are shaped differently? If I could find an arm with even 1/2" drop it would fix the problem.
