• Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' the posts that you read.
93 2wd vs 4wd pitman arms
19Walt93
Well-known member
981
Canaan,NH
351
I replaced the manual steering box in my 93 2wd with a power unit to make driving with a 351 easier. The truck had dropped I beams. The manual pitman arm had a slight drop built into it and the power one is straight which puts the drag link closer to the front oil drain plug than I like on full right turns. Does anyone know if 2wd and 4wd pitman arm are shaped differently? If I could find an arm with even 1/2" drop it would fix the problem.
Rock Auto 5% Discount Code: 4FF3E9EEA14805 Expires: October 1st, 2020
4x4junkie
Forum Moderator
274
So. Calif (SFV)
2.9L V6
35x12.50R15
The 4WD arm has approx 2" more drop than a 2WD arm.
Stock 4wd arm at left:
19Walt93
Well-known member
981
Canaan,NH
351
That's great, thanks. My 2wd arm is straight so a stock 4x4 arm might do what I need.
