calebrk
- Jan 24, 2008
- 0
- va
- Ford
- Engine Size
- 4.0L v6
As the title says, I'm wondering if there's a way to extend the pushrod that links the clutch pedal to the master cylinder. I recently replaced the slave cylinder and the clutch. I've bled the system as prescribed in so many places. I removed the master from the truck twice already. I inverted it, pumped it and tapped the line. I've bled it in the truck using the bleeder valve probably 50 cycles now. It seems so close but still not right.
I feel if the push rod was a little longer it would give me the amount of pressure needed to make everything work. Is there a procedure to do this, does anyone have a way to engineer it themselves, or do you have other ideas?
Thanks in advance for any help
