RedNeckRanger
- Oct 2, 2007
- 0
- Ford
- Engine Size
- 3.0L
My '91 Ranger 3.0L has developed a high idle that I can't seem to figure out. The truck starts fine, but idles at about 1800 rpm. With the IAC unplugged, the idle does not change. I backed out the throttle stop screw until it was not touching, but no change. The throttle plate is closed, and if I block off the IAC where it bolts to the intake, there is still no change! I have checked for vacuum leaks at the manifold, IAC etc and found none. I tried cleaning the IAC anyway in case it was stuck open, but no change. If I scan for codes, there are none present. If I run a KOEO test, it passes. If I run a KOER test, I get a code 13, unable to control idle at low rpm idle test. I am thinking maybe there is something going on with the timing and this is affecting the idle speed? I am going to disconnect the SPOUT and check the timing. Anyone have any other suggestions?
