88 EXT cab ranger v8 swap pics
kamshaft
appleton wi
347
"update" this is my truck so far . im 19 this is my first major vechicle resto tell me what you think
and yes the last pic in this post is a hydro handbrake
kamshaft
appleton wi
347
thats how it sits as of right now but i have a qwick fuel 600 dp carb now and gilmer belt drive.
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
What are the engine spec (year, vehicle it came from, etc..), intake your using, etc...
I plan on doing a 302 swap this spring.
Looks good, tired of the lack of power my 2.8 has, good engine, not enough ass to it though.
stegomon
20
auburn/minot maine
fords and only
baaadd assss
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Looks good so far. If you made your motor mounts solid, you need to make your trans mount solid too, otherwise you will crack the bellhousing all the way around. Keep up with the pics!!
SVT
doorgunner
Lab Rat for V.A. hospital
MTOTM Winner
2009 Truck of The Year
516
New Orleans (8' below sea level & sinking)
350+1
N/A
3/4
23570R15
JESUS Loves Ya!
looks real goooooooooooooooood....
keep taking the pics!!!!!!!!!!!!!!!!!!!!!!!!
:yahoo:
kamshaft
appleton wi
347
thanks ! the motor is an early 86 thunder chicken roller motor it is bored .30 over 347 cu. flat top pistons 9.5:1 compression e303cam, performance products aluminum high rise intake moroso 1"carb spacer march racing alternator bracket and high flow standard rotation water pump and timing cover 403hp at 5900 and 417ftlb at 2900
dangerranger83
54
Lafayette, IN
:headbang::icon_hornsup::icon_surprised::drool: :woot::sexe::pray::rockon::icon_thumby: :icon_bounceblue::icon_bounceblue:
:icon_bounceblue: :icon_bounceblue::icon_hornsup::headbang: :shok::icon_cheers:
Hope that sums it up.
jhammel85
Guest
Nice specs on the motor!
Looks good! keep up the good work!
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
thanks ! the motor is an early 90s roller motor it is bored .30 over 306 cu. flat top pistons 10.5:1 compression e303cam, performance products aluminum high rise intake moroso 1"carb spacer march racing alternator bracket and high flow standard rotation water pump and timing cover 395hp at 5900 and 417ftlb at 2900
how did you get those numbers?? remote turbo with this version?
those looked like reg iron heads to me....if they are some bad ass afr's or something then correct me...sometimes pics are decieving.
with 10.5 to one i can see 3-330 crank hp for sure with an e cam.
350 plus with an e on a naturally aspirated is tough task....:icon_confused:
300 plus with this setup needs some help...hard to squeeze 350 hp through that exaust with out a turbo.
at least with what i have built.
kamshaft
appleton wi
347
i have ported and polished 351 heads off of a 74 stang 194 intake 160 exhaust and about 12 hours of portin in each head
kamshaft
appleton wi
347
i have my doubts myself i thought a 347 would be those kind of numbers
kamshaft
appleton wi
347
howd you get those pics to upload? everytime i tried they were small or didnt work
