88 2.9 fuel problems
88ranger4x4offroad
Corydon, IN
1987 and 88
2.9L
There was a similar post in the old forums. I am having a problem with fuel as far as I know. Haven't gotten a gauge to check fuel pressure, but when I run my truck at part throttle it seems to be loading up and puking out puffs of black smoke. I have replaced the water temp. switch and dist. pickup. Also swapped intake temp. switch and throttle pos. sensor. Also tryed swapping computers. No success. Now after it runs for about 5 or so minutes it just dies with no spark. I am getting really pissed off. :annoyed::mad::icon_confused:. Please any help would make me ecstatic. Thank you.
holyford86
Some guy with a problem
636
Plattsburgh, NY
many
33x12.50R15
tfi module, classic symptom. There is a possibility that it could be something like a bad ground to the computer or a bad eec relay but those really arent heat related issues.
88ranger4x4offroad
Corydon, IN
1987 and 88
2.9L
Just had my Holley TFI module tested and no problems there. That is what they said. We will see. Got more important things right now. Too many vehicles need work.
MAKG
19
California central coast
These are not at all classic TFI symptoms. The TFI failure gives (sometimes intermittent) no spark conditions. You don't screw up the mixture. You stall and can't restart until the distributor cools (or permanently).
Run the self tests. Many mixture problems are caused by faulty inputs to the PCM. Check every ground (electrically -- you often can't see poor grounds unless they are severed).
88ranger4x4offroad
Corydon, IN
1987 and 88
2.9L
This may sound stupid and I know my truck inside and out, but what self tests? I just want my truck fixed so I can enjoy it again. Thank you.
holyford86
636
Plattsburgh, NY
many
33x12.50R15
... Now after it runs for about 5 or so minutes it just dies with no spark... Thank you.
the reason I say it could be a failure of the tfi is because of that statement and if you read my full reply I also touched in the fact that it could be a wiring issue. yeah, i might not know it all but you dont need to crawl down my throat for trying to help a guy out.
Psychopete
29
FW, IN
During the self test, the computer can check for incomplete circuits, voltages that are out of range, etc.. Do you have a CEL present?
You can visit this link or the technical library for info on pulling codes:
http://www.troublecodes.net/Ford
Follow the diagram on the bottom right picture, put the key on 'Run' and simply just watch the codes blink out on your CEL. It will show the engine ID, KOEO codes (hard faults), BLINK, then CM (codes in memory) codes. The codes will be repeated twice. If the CEL is burnt out, use the top method with the analog voltmeter or test light (or if the current reader has an 86-87 model).
Pete
88ranger4x4offroad
Corydon, IN
1987 and 88
2.9L
Thanks for the help. I am gonna check soon. Thank you very much. Have a good night. Any more help would be appreciated. O and Holyford86 I did not jump down your throat just saying what I knew.
robo
check for corroded grounds at battery terminals. if the cables are swollen at the battery the corrosion swells the plastic and insulates the wires causing poor a ground.
88ranger4x4offroad
Corydon, IN
1987 and 88
2.9L
Thanks. I am about tired of trying to figure this out, but I have way too much money wrapped up in this truck to give up. I got a constant memory code of the dist. pick-up. Replaced it with a new one and now the truck will only run for a few minutes before it dies with no spark. I have checked all the plug wires, replaced cap and rotor, cleaned the plugs, swapped coils, checked ICM, checked fuel pressure, checked and swapped coil, swapped intake temp. sensor and TPS. Not sure what to do now. I am gonna try a different MAP sensor next I guess. Trying to not throw new parts at it untill I find something that changes anything. Thanks again for all the help.
88ranger4x4offroad
Corydon, IN
1987 and 88
2.9L
Ok, let's try again. What we have here is apparently replaced a perfectly good dist. pick-up with a bad one. Took it back and got a new one. Back to original problem. Got truck running so now I could hook up my tester to it. KOEO codes were 11 with a Continuous Memory code of 96( by the book that means: Thermactor Air System problem--right(passenger) side air flow will not bypass OR Fuel Pump circuit failure OR High speed fuel pump relay circuit failure). Confused me too. No idea which one that is. KOER codes are 12 and 41. 12 meaning System cannot raise engine speed above normal idle. 41 meaning Exhaust Gas Oxygen sensor: voltage signal always "lean" (low value) -- does not switch. Please any similar problems that were solved would help. Fuel pressure is a little low, but should solve with a new fuel filter. Any help would be greatly appreciated. Still smells like gas and can't figure out if it is loading up or missing under partial throttle. Comes and goes though. Totally frustrated. Please help.
derekj
Squamish, BC
Ranger 4wd
I will see what i can dig up when i go to work tomorrow.
Derek
88ranger4x4offroad
Corydon, IN
1987 and 88
2.9L
Will drive shortly to see, but I think a new oxygen sensor solved my major problem. i am stupid. Heard other people didn't solve their problem. hould have tried it in the first place. Thank you for all the help. I appreciate the info. Should have just used my computer in the first place.
