87 A/C Retrofit questions/checklist
85_Ranger4x4
17,975
SW Iowa
I don't see a drier...
tx_pwp5
Austin, TX
4 inches
31x10.50
More auto shenanagans on instagram @waterloocustomworks
85_Ranger4x4
17,975
SW Iowa
tx_pwp5
Austin, TX
4 inches
31x10.50
Anyone know how much ester oil needs to be used?
tx_pwp5
Austin, TX
4 inches
31x10.50
"Remove the compressor and stand it on it's end and let the oil drain out. Spin the clutch as you do this. When it's empty, add about 3 oz of Ester oil. Spin the clutch by hand again to let the oil get distributed in the compressor. Reinstall it in the truck and try not to let any oil spill out. Pour the rest of the oil in the new accumulator. The total oil capacity is 7 oz, so I would pour about 3 oz in the compressor, and 4 oz in the accumulator."
^quote from another thread on this site by exbass94 talking about (I believe) a 93 2.3
__________________
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
For my '90 2.9L it's 10 oz of refrigerant oil. I believe '87 has the same FS-6 compressor, so it's quite likely yours needs 10 oz also, but I'd suggest double-checking it to verify.
(my '94 4.0L w/FS-10 comp uses 7 oz)
85_Ranger4x4
17,975
SW Iowa
Is that dependent on the compressor or the system?
tx_pwp5
Austin, TX
4 inches
31x10.50
Awesome thanks for the heads up on this. Last thing I want is to lose the compressor and have to redo everything. I only ordered 8 oz.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
I would assume compressor, as the rest of the system is pretty much identical outside of some slight differences in hose lengths and orifice size.
85_Ranger4x4
17,975
SW Iowa
I am putting a 96-01 Explorer A/C compressor (to go with the belt system of my 5.0) in my '85... so there is some system differences in my case. :derisive:
tx_pwp5
Austin, TX
4 inches
31x10.50
So far there have been a few things that are different that I've noticed.
The wiring harness changed between the 1st and 2nd gens.
The condenser is bolted directly to the core support on the first gens, and has L shaped brackets that mount to the core support on the second gens.
The A/C panels are (of course) different, especially the shape and texture of the buttons. This is probably just appearance stuff, but still good to know.
I THINK the belts might be different, but not totally sure. There were two sizes available when I ordered mine, both "compatible" with the 2.9.
That covers what I can think of off the top of my head.
85_Ranger4x4
17,975
SW Iowa
I have noticed the condenser itself is different too. First gens have both inlets on the PS and second gens have one inlet on each side.
tx_pwp5
Austin, TX
4 inches
31x10.50
good catch I forgot about that. That would change the hose length too I would imagine.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
But unless the capacity (size) or the flow-design of the condenser is different, I'm not sure any of that would matter.
Maybe you might ask over on www.autoacforum.com. There's probably some experts over there that could answer that question better than I can.
85_Ranger4x4
17,975
SW Iowa
I am shooting for the second gen condenser. Like my 2.8 had the compressor on the DS (same as my 302 will be) so for the first gen setup I would have a hose going from the evaporator to the condenser, then another hose coming out of the condenser and wrapping around the back of the engine coming up to the compressor and then another hose coming out of the compressor, wrapping around the back of the engine again back over to the evaporator.
With the second gen the condenser-to-compressor pipe right in front of the compressor so you lose one of the hoses looping around the back of the engine. Cleaner looking install and fewer variables for those of us that are not stock and will probably have to make our own hoses.
So far I only have the harness and the half of the A/C box I didn't mangle trying to fit with my tall valve covers. For the generic Sandon compressors we upgrade tractors to at work I think it just says with the compressor how much oil, not really caring what color tractor it is going in. I will have to pay more attention to that. :dntknw:
