- Nov 12, 2018
- 510
- Alcoa, TN
- Engine Type
- 2.8 V6
- 2WD / 4WD
- 4WD
Hey guys, have a weird problem I'm trying to diagnose.
My B2 has a weird shudder it has developed.
It only happens when I come to a slight incline at 45 mph and at a certain throttle position. If I give it more gas and up the rpms it seems to go away. If I let off the throttle completely and let it coast, it goes away.
It happens at 45 mph and will stay until around 50ish unless I give it more gas.
This is when I am in OD on the trans selector, but it is in 3rd gear.
Any thoughts? 2.8 carb with duraspark distributor and HEI.
The rig seems to be running great otherwise. I don't believe it is tire or wheel bearing related, and my driveshaft is brand new.
Could it be leaning out or something? It has been doing it consistently and I have done some carb adjustments (went from #48 -> #49 jets) and I got the timing set correctly after setting the lash on the valves. All of that had no effect on the shudder.
Only other thought I have is a torque converter shudder, but it is brand new in my recent rebuild adventure.
Any thoughts?
@19Walt93 @RonD @Uncle Gump
Any thoughts?
