83 cluster plug conformation??
Angie
368
Vancouver area BC Canada
92 & 83 project
4.0L 302
hi all,
needing to know if these pins are correct for a 83, gas, gauges, 2.8 (when originally built) .... no electricity in the truck, dash is semi apart, truck is being rebuilt.
here is link to the 18 pins on the cluster.
http://www.therangerstation.com/forums/showthread.php?t=156485
top right is the pin block i am going off. thanks for any help.
#1 ..... yellow/white fuel sending
#2 ...... white/red oil sending
#3 ....... open
#4 ........ open
#5 ........ black / light green ground ?
#6 ........red/orange ground for amperage meter ?
#7 ........open
#8 ........ red/white temp sending
#9 ........ yellow/light green amperage positive ?
#10 ...... light blue/red panel (dimmer lights)
#11 ..... open
#12 ...... red/yellow ???????
#13 ...... pink/white ???????
#14 .......black ground
#15 .......dark green/light green seat belt
#16 ....... light green/black right turn signal
#17 ........ white/light blue left turn signal
#18 ........ light green/white high beams indicator
rtg143
ASE Certified Tech
61
Oregon
5.4l
This is for 1986 but may be the same. Check the upper corners.
Angie
368
92 & 83 project
4.0L 302
hi bert, thanks for the wire dia. that is the same one i had linked to.
what i am needing is if the wire pins in the block are traced back to the proper sending units, grounds and such. I only want to repin the block once when i swap the block into the 85 case from using the 83 case.
here is a link to the full thread if these pics help any.
post 17 shows a bit more.
http://www.therangerstation.com/forums/showthread.php?t=156327&page=2
thanks
rtg143
ASE Certified Tech
61
Oregon
5.4l
Ford uses the same color wires all the way through those years, even into the 90's if that's what you mean.
rtg143
ASE Certified Tech
61
Oregon
5.4l
Is your question about where the lines go where you have question marks?
3,614
Be careful with black wires. There is a solid black wire that is power to the gauges. It is a 9-ish ohm resistor wire and comes out of the ignition switch. If you don't have it in place none of the gauges will work, if you replace it with a regular wire you will burn the circuit board.
I think the ground for the cluster stuff is actually black/white.
Angie
368
92 & 83 project
4.0L 302
hi bert, yes questioning the ones with ? marks and also wanting conformation that the others are correct. i am guessing i have it pretty close to right. pink wire is actually purple though.
hi adsm, the only gauge i was going to use the original wires were going to be the fuel sending unit (aftermarket fuel gauge). the temp, and oil are going mechanical, and going to be directly wiring the amperage.
the ground wire you are talking about, is that needed for the fuel? if so, is it the pin with 2 black wires on it? i didn't see any black/white wires, just solid black.
thanks
