Junk Collector
Truck of Month
- Mar 4, 2008
- 4,806
- Rapid City SD
- Engine Type
- V8
- Engine Size
- 5.0
Annoying new problem - I recently 8.8 swapped one of my trucks with an Explorer axle. All was fine for the first few drives around town, parked the truck in the garage for a couple weeks and now when I roll it back & forth by hand in neutral, or drive it back & forth slowly, I get a horrible low pitched groaning noise from the rear end. I have narrowed this down to something in the brakes - I had the rear end off the ground and it'll make the noise when I spin the tires. Removed driveshaft, same thing. Removed calipers & rotors, no noise. The driver's side parking brake shoes were way too loose so I adjusted them and it seems 95% better, nothing weird happened on my test drive, parked it in the shop again and the noise is back a few days later.
Any ideas? Literally everything in the rear brakes is new except the calipers. The backing plates and caliper brackets were sandblasted & painted, everything is nice and clean so I'm not dealing with rusty old junk here. I am leaning towards an adjustment issue with the parking brake shoes but it's sort of confusing that it went away and now it's come back.
