8.8 Carrier compatibilities?
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
So I’m planning on buying a locker and regearing my 91 explorer 8.8 that I just swapped into my 89 Ranger. While searching lockers I see mainly “Mustang 8.8 locker” for 28 or 31 spline shafts. I saw in the tech section that not all 8.8 carriers are interchangeable. The spline count is obvious but what other issues prevent the carriers from being universal?
What is the correct carrier or locker description to buy for an explorer?
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Thanks, I knew the explorer 8.8 is 31 spline. I just want to make sure that the carriers aren’t different. I read the later independent suspension 8.8 has a different sized carrier than the solid axle 8.8 but I’m just trying to confirm that a solid axle 8.8 carrier is universal so I don’t have to worry about accidentally ordering the wrong carrier. Also in that thread that you just shared, someone said all 8.8 gears fit the carriers. Is this true? I thought that all carriers were designed for a specific ratio range, for example 4.10 and down or 4.56 and up? What makes the 8.8 different?
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
I'm not sure on the 8.8, but the Dana 44 has two different carriers for the gear sets. 3.73 and higher, and 4.10 and lower. So it would not surprise me if the 8.8 had 2 different carriers for gear sets.
When buying new the site should state what gear sets it covers if they do.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
snoranger
Professional money waster
ASE Certified Tech
13,700
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Lol but I don’t want that one. I was planning on getting a lockright. But that was if I had to buy a new carrier to regear. If I don’t have to buy a new carrier tp regear to 4.56’s. If that’s the case, then I will buy a cheap locker to put in the stock carrier.
scotts90ranger
4,445
Dayton Oregon
2.3 Turbo
There aren't carrier splits in the 8.8" axles.
I had an Aussie locker for years in my Explorer 8.8 with a fair amount of abuse but not too many miles, that eventually gave up so I threw a Yukon Grizzly carrier in it I got off Amazon for fairly reasonable... with the oil leaks and building a shop I haven't had much time to drive it in the last year though... it's been wheeling a few times with good results though.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
So for future reference.
As stated by Scott, the 8.8 carrier doesn’t have a gear ratio split. Any gear ratio can be mounted on the stock carrier.
The HP D35 TTB has a gear ratio split of 3.54. As long as your axle has 3.54’s or numerically larger gears, you can regear up to 6.13 or whatever the “lowest gear ratio” made for them is.
This will save me quite a bit of money. I will be buying gears and lockers for it when my taxes come in.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
The HP (TTB) D35 does not use the gear split either (unlike a Jeep rear D35), even if it came with 3.27 gears. All HP gears mount on what would be the "3.54 & up" carrier.
5.13 is deepest ratio offered for the HP D35.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
That’s good info, thanks 4x4junkie!
