7.5 limited slip does any one now who makes this
bf750
12
Ky
2. Crap
It is what it is
CorbinsRanger
114
Saskatchewan
FX4
31x10.5x15
Saskatchewan...hard to spell...easy to draw
Kind of looks like this? If so it's a Ford 7.5 Eaton Detroit Truetrac Differential. This is as close to what you have I could find.
19Walt93
4,484
Canaan,NH
351
3"
235/55R16
I don't think that's a truetrack, it looks like a clutch type diff. Can you get a good picture of the letters and numbers on the end of the case?
CorbinsRanger
114
Saskatchewan
FX4
31x10.5x15
I was looking at the bolt locations and physical characteristics of the unit and this one is the closest I could find. Will do a little more hunting
2011Supercab
469
Washington
Toyota Tacoma
Looks like a DANA, but if you're after more than clutch packs, you'll be better off just buying a whole new carrier unit.
pjtoledo
2,989
Toledo Ohio
Fords
3.0 2.3
tru tracks don't have side gears or cross pins.
those bolts hold the case halves together.
pjtoledo
2,989
Toledo Ohio
Fords
3.0 2.3
looking at it again, it has cones not friction packs behind the side gears.
00t444e
217
Southern OH
Ranger ext cab
Definitely an Auburn limited slip (Posi).
19Walt93
4,484
Canaan,NH
351
3"
235/55R16
Turbo Coupes used 7.5's with Auburn limited slip diffs. I have an Auburn Pro in my Mustang. The bad news is they are not rebuildable and when working properly they shed metal particles into the gear lube. No Ford ever used a posi.
bf750
12
Ky
2. Crap
It is what it is
Thanks for the info
19Walt93
4,484
Canaan,NH
351
3"
235/55R16
4x4prepper
216
Atlanta
Good to know what to avoid.
No members online now.
