DevinMull
- Mar 30, 2015
- Reaction score
- 0
- Make / Model
- Ford
- Automatic
Well let's start for the beginning I was driving home from work one day and I get on the interstate and it work shift into overdrive the the o\d light starts flashing I continue to drive it home about 20 miles. By the time I get home I barley make it into the driveway just stops no gears at all. So I pull the tranny rebuild it new clutch's o rings gaskets bands troque converter. I test the solenoids they tested OK. Get it all back together and the damn thing still doing the samething. When its cold it shifts with some slipping. When it gets warm it won't go in to gear any gear. Oh yea I check the vb for warpage. The only things I haven't done is taken it to have it scanned or done a line pressure check. When in reverse its like its in N until u give it gas u can feel it shift into reverse. I also treat my lil ranger like it a one ton. I have a plower on the front and haul more wood than what the truck weight is. I pull trees limbs. Pretty much everything it wasnt design to do i do with mine. Any help will be great. I'm about to give up lol. Thanks
