RedBowTies88
- Oct 5, 2021
- 1
- Cape May, NJ
- Ranger
Hi guys.
I both hate and deeply distrust automatic transmissions, however I did just buy my dad a ‘94 4x4 4.0 with 77k because he’s getting up there and is tired of driving manual.
I’m trying to change all fluids and make the trans as reliable as possible. It’s currently working correctly. I plan on regular fluid/filter changes and adding an external cooler to use instead of the one internal to the radiator.
I was told by a questionable source that I could swap the A4LD pan for a 5r55e pan and gain both some capacity and a drain plug. Is that true?
Also, is routing the trans lines out of and away from the stock radiator a viable option? I’m sure that an external cooler will perform better, but I’m not sure if the trans fluid temperature is regulated to some extent above ambient by the stock rad/trans cooler combo. In other words, will completely separating the trans cooler from the radiator create a situation where the fluid is too cold to perform correctly because the engine coolant isn’t warming it?
thanks.
thanks.
