5.5" Superlift question
Evan
5
Stevens Point, WI
4.0 OHV
I bought this 5.5" Superlift. I plan on using 4.5" ZJ springs with some spacers for about 3.5" of lift. Since the brackets are for a 5.5", can I just move the pivot bolts up to the top hole on the brackets? From the pics it looks like there's an extra hole there.
CopyKat
8
Manitoba, Coldest place in Canada
They have pivots for a 4" and a 5.5" lift.
I've got mine in a 4" pivot and I'm running about 3.5" lift. One day I'll get around to building new 1.5" lift brackets and then cut my beams for the rest.
Evan
5
Stevens Point, WI
4.0 OHV
I'm looking for between a 3.5-4" lift. So I'll put the pivot bolts through the top hole. I have a set of 4.5" ZJ springs that I could use with a 1" spacer which I believe would give me 4" of lift. Or, I could use the 5.5" Superlift springs and hope that with my heavy winch and bumper it'll settle to 4"?
Thoughts on the springs I should use?
crawlin91
60
Crawlorado
2.9, 4.0
im using the superlift 5.5" brackets on the bottom hole with 6" soft ride skyjacker coils and no spacer, with the FR34 4" leafs and F150(smaller than ranger)blocks for the rear.
seems to sit about right....may add a washer spacer up front in the future
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
The ZJ springs with spacers should work well in the 4" (upper) bracket holes (assuming your Ex is 2-dr).
I would reinforce the bracket supporting the driverside beam though, the tabs like to fatigue and bust off those.
Evan
5
Stevens Point, WI
4.0 OHV
How about putting a bolt through the bottom hole with "pinch" nuts on the inside. Would that reinforce it without interfering with the operation of the beams?
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
:icon_confused:
Not sure what you're asking... Click the 2nd pic for bigger, the tabs are reinforced with gussets to keep them from flexing and ultimately breaking off.
canyoncritter
6
San Diego
Willys,Ford,Jee
might want to plate the ears of the radius arm's now too. As they are known to snap.
Evan
5
Stevens Point, WI
4.0 OHV
I wonder why Superlift doesn't make them stronger?
I guess I'll beef 'em up tho.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Oh yeah, forgot about those...
These are reasons why Superlift TTB lifts don't come that highly recommended around here lol. At least you got the newer redesigned bracket that won't bust through the diff housing (instead of a drop plate).
Evan
5
Stevens Point, WI
4.0 OHV
So does anyone know how much the 5.5" springs would settle? 2dr Explorer with a 4.0 and 300 lb winch+bumper.
BlackBII
Ranger Custom
Truck of Month
984
UT
Here is a shot of my 5.5 Superlift about a week after I installed it.
It leveled out for near perfect camber after a few weeks. Stock frontend with a 2.9, no winches etc.
I would say 3/4 or so
You can look here, my photobucket. There are some pics of my BII when it was blue, right after I put the lift on, and there are some after I painted it black, and the springs have settled.
http://s105.photobucket.com/albums/m205/danteinien/BII/
Evan
5
Stevens Point, WI
4.0 OHV
So your's settled about 3/4 to 4.75".
I'm thinking mine might settle to 4", with the bumper/winch, 4.0, and because the springs I'm getting are 3 years old.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
I would expect somewhere between 4.5-5" lift out of that setup (unless those are "4.0" coils, which will sit about a half-inch taller). The Superlift TTB springs are stiffer than others like Skyjacker, and shouldn't settle as much with added weight.
You're not going to use the ZJ coils?
Evan
5
Stevens Point, WI
4.0 OHV
I think I'll end up using the ZJ coils. Just wanted to see what the Superlift coils were capable of.
My plan is to have 3" BL and then 3.5" SL with the ZJ coils, for a total of 6.5". I think I'll end up with some good flex, keep the CG relatively low, and have enough clearance for my 35s. Right now my 35s rub at times with 5.5" and mildly trimmed fenders. And my flex is limited with F-150 coils and stubby stock rad arms.
