4 inch lift...brake lines?
rangerdude91
virginia
4.0, 2.9
i just bought a 4 inch Rough Country lift for my 1995 4x4 ranger. with this lift am i going to have to extend the brake lines or should it be okay?
thanks
nathan
Bent Bolt
4
Edmonton,AB
Supercharged 4.0 SOHC
Solid Axle Swap 4x4
You're going to need extended brake lines. I have braided lines made for 4" lift. Some guys use lines from a superduty F350.
94EXPLODER
Traverse City, Michigan
4.0 150k
yes you will need to extend them...at auto zone or murrays its about $40 total.
BEEFKING69
Blountstown, Fl
FORD
302
how bout 2 inch lift in the front?
rangerdude91
virginia
4.0, 2.9
ok thanks alot
Scrambler82
11
SoCal
Ford/EDGE
4.5" SL
WWWhhhaaattt !?!
33 x 12.50
With the extended lines make sure to tie them up against the spring so they won't rub.
I lost the first set that way.
