4.0L Engine Swap - Engine removal Question
belovedb2
This may seem like a stupid question for all you experts. Where do I attach the engine hoist chain to the 4.0L engine that I am removing from my 93 explorer doner vehicle? I do not want to break anything by using something to weak. Where is the correct spot? Do I need to buy a special bracket or plate? Thanks Update: I just noticed on the 2.9L engine some heavy wire loops that are bolted on each side of the engine. I suspect these were used for installing the engine. Can I use the same loops for the 4.0L engine?
After looking at each engine I think I can use the same loops. I need to verify after I remove the loops. The only issue is the center of gravity. I am guessing the loops are set with the trans attached to the engine. I am removing the engine without the trans.
trail B2
8
North Eastern Ca.
Pull engine
I just used accessory air cond bolts I think and put A bolt in the intake on the back but I had one of those screw adjusters to tip the motor how I wanted.
Fx4wannabe01
February 2010 OTOTM Winner
20
Boring, Oregon
in between a few runners on the exhaust maifolds, are dedicated empty bolt holes for your lifting chains. Use a spreader bar. I just swapped engines in my '01 4.0. Your holes may be different on the OHV though.
BlackBII
Ranger Custom
Truck of Month
982
UT
There should be empty bolt holes on the side of each head. I usually hook one end on the back and one on the front - opposite sides. Lifts out more evenly that way. :icon_thumby:
rickcdewitt
5
nor-cal
4-0 swap
i put the lift tabs from a 2.9 on the exhaust bolt holes mentioned
