shadow88
CLOQUET MN
FORD
My donor is a 91 going into 90 b2 so hopefully it goes good
BroncoIIer
Oklahoma
4.0L OHV
The headlights will need to be spliced for sure. The explorer ran the wires for the tail lights through the body while the bronco II is run along the frame rail. I don't remember exactly where they tied in the harness at though.
BroncoIIer
Oklahoma
4.0L OHV
Sorry just noticed you have a '90 model. I have an '88 with the older style headlights so there is a good chance you wont have to.
shadow88
CLOQUET MN
FORD
So what your saying is, I change the harness from the cannon plug, and maybe splice in the head and tail lights, am I going to have to repin anything at the cannon plug?
shadow88
CLOQUET MN
FORD
I've been looking at my donor and the b2 wire harness, the head light parts are the same, so maybe I'll only have to splice the tail lights? Where are the plugs? On the drivers side?
3,614
Only if the engine harness you get is from an Explorer. A Ranger harness is a perfect match.
shadow88
CLOQUET MN
FORD
I want to change the oil pump before I drop the 4.0 in, what are your thoughts on a high volume pump compaired to a stock? Is it worth the extra $45 in a used motor?
shadow88
CLOQUET MN
FORD
Started to swap the wire harnesses, there's two plugs on the fender on each side of the b2, right next to the head light and blinker plugs, I'm guessing these are the tail light plugs? Anyone help on where to splice these into 4.0 harness?
shadow88
CLOQUET MN
FORD
I got the wire harness in from the donor and all my lights working, so far no splicing, ran out of oxygen in the torches or I'd have the 4.0 in, hopefully I'll get it in on Thursday,
shadow88
CLOQUET MN
FORD
Getting real close!
4.0B2
151
Walls, MS
4.0 v6
man I would have cleaned that motor up before installing it.. lol.
so everything is working out so far?
shadow88
CLOQUET MN
FORD
Believe it or not the motor is cleaned, the intake is really stained, I plan on painting it and the valve covers, I just want to get every thing running befor I paint it up, so far my only trouble is I have to figure out the reverse lights, motors from a auto, I have a manual
shadow88
CLOQUET MN
FORD
Ok I got everything hooked up, turn the key and nothing, fuel pump kicks in, all lights and stuff work, any ideas where to start? Battery posts are cleaned, checked my connections,
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
the two wires from your power distrib ution block to your neg batt cable could be undone or have a badd connection.
shadow88
CLOQUET MN
FORD
Got it to start by jumping solenoid, but it chokes out if I give it to much throttle
