4.0 refresh
2old4this
NJ
I'm thinking of doing a refresh, rings, bearings, gaskets, seals... nothing major but I've read that the rockers & pushrods tend to wear excessively. Is there a cure, & does anyone make unproved aftermarket rockers? I'm not lookin to Hot Rod it... well maybe I'll put in a mild cam. Just lookin to refresh and remove any weak links.
Thanks
Pat
Stranger ranger
How many miles on the momo? Probably don't need to refresh rings, bearings, but gaskets and seals are possible. The rockers and pushrods do tend to wear excessively however, the only thing it really causes is a annoying tick. And you might hear a tick now, but its probably your injectors, a pushrod tick/tap will normally appear once the motor is warm. I believe its deltacam that sales hardened pushrods and arms to replace the stock ones. If your not gonna "hot rod" it, don't F**k with a cam. My pushrods were noisey for 2 years, and when I finally replaced the motor, for really no reason at all just to do it because I had a lower mileage spare, neither one ran any different, just more quiet. FWIW
2old4this
NJ
I have 170,000 and it's leaking everything from everywhere, wrecking my driveway! Maybe I'll just clean it up and put a gasket & seal kit in...oil pump...water pump...?
Stranger ranger
Rear main, front crank pulley seal (if needed), valve cover gaskets. Replace oil pump if its bad, same goes for the water pump. If it aint broke, dont fix it
woodyedmiston
4
Texas
If they are still around, deltacam.com used to have hardened push rods and improved rockers. They were not too bad $ wise.
