31 spline 8.8 swap questions
Colin
182
ON Canada
Mazda
Going to be swapping in a Torsen 8.8 soon and just had a couple quick questions.
When I get new ubolts made does anyone know the size off hand?
I know the tube is 3.25"
Also when I bought the axle I didn't get the leaf spring/ubolts plates, I assume the normal 8.8 plates won't work?
don4331
1,346
Calgary, AB
5.3
Explorer U-bolts/plates work, for what its worth, the plates will just the the extra metal for the shocks. You can grind off the tabs if you have the tools. F-150 plates/U-bolts work too. In theory, you are supposed to get new u-bolts anyways.
When I had u-bolts bent up, I had axle in back of truck, and shop took measurements right off the axle in the truck and bent the up on the spot.
Colin
182
ON Canada
Mazda
Perfect thank you (y)
No members online now.
