Junk Collector
Truck of Month
- Mar 4, 2008
- 4,800
- Rapid City SD
- Engine Type
- V8
- Engine Size
- 5.0
The only 31 spline Ranger axles came out of FX4 trucks. So an Edge 2wd will not have one... simple as that. The junkyard guy is not telling you accurate information.
What you want does not exist as a factory Ford part. The chances that you will find it in the junkyard are very close to zero. If you want 4.56 gears you will have to buy an axle and have them installed.
Not quite sure what you are after as far as lockers go... A Torsen is a limited slip, not a locker. Aussie, Lock-rite, Detroit, ARB, Ox, Zip, E-Locker, Spartan... those are lockers. Your G80 technically is too but they have a well earned reputation for being called "grenade locker" because of how they engage.
