302 Carb'd swap into a 90 BII
WNY964x4
ASE Master Certified
Firefighter
ASE Certified Tech
9
East Pembroke , NY
Chevy,Ford,BMW
alot of different ones
ok , i am gonna do a 302 swap into my 90 Bronco II Mud Truck and i have a few quick questions and hope to get some answers before i get to heavy into this
1. What can i do for Engine Mounts ? Can i use the stock ones from a 90's Explorer V-8 or does an aftermarket company make them ?
2. When it comes to wiring i want simple , and i need to know if i am gonna have to run new wires for the headlights and such because i plant to remove the ECM and complete wiring harness , is there any way to seperate out the lighting harness when i do this ? (truck will still be driven on road)
3. What are your opinions on removing the heater box assembly completely and running a low temp T-stat ?
thanks for any info guys
baddad457
18
Opelousas La.
The EFI harness is separate from the lighting harness. Motor mounts? 85-03 Mustang 'vert mounts. Low temp T-stat ? I ran a 160* in mine for years to keep the temps down.
ecablarn
Michigan, Bay County
Ford / Ranger
302 V8, Mild Frame off Restoration still have bodywork
Leveling 2" Lift
31x10.5xR15
BSME, design, drawing
I hear L&L mount work good but mustang vert mounts are probably cheaper. I bought Advanced adapters mounts but don't recommend them.
Why do you want to get rid of you heater core/ heater box?
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
bout all that needs said was:icon_thumby:
i assume its a mud monster and likely modded windows so no need for hvac.....
put a plate on the firewall holes and call it done
