300 straight6 swap
4banger_ranger
Kingsland, Ga
2.5L
i have a 2.5L, but i want something with more torque has anyone swapped from a 4banger to a straight6???
3,614
This is a topic that has seen quite a bit of discussion lately. The general consensus from those who have done it is that it is not worth the extra effort over something like a 4.0 or 5.0 to swap in a 300-6. They are long, they are slow, and they get terrible gas mileage.
lil_Blue_Ford
6,221
Butler, PA, USSA
4.9L
I haven't actually seen one completed and driveable yet.... though lots of people have talked about it.
The 300-6 is a great motor for what it is, but it's long, heavy, and will not generate the same results as a 5.0 swap. The one thing that makes a 5.0 swap easy is that since Ford put it in the Explorer, they had to shorten things up to give some extra room for things. That can help a lot in an engine swap. I have seen Rangers and BIIs done with the full-length components, but after having done a 5.0 swap into a Ranger myself (a project between myself and my dad), having those shorter components on the front made things a lot easier. No messing with whacky motor mount settings, no bashing the firewall, it just fit.
No such components were made for the 300-6. And it's a longer block than a 5.0 because it's an inline motor. The 5.0 only sports 4 cylinders deep since it has 4 on each side of the block. The 300-6 is 6 cylinders long.
4banger_ranger
Kingsland, Ga
2.5L
yes they are slow, but they have alot of torque with is what i want.
3,614
Ok, you keep saying you want torque. What you haven't told us is what you want to DO.
There is a difference between what you want, and what you want to do. Maybe we know a better way than swapping in an engine that doesn't fit.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
so your impressed with 200 pounds of torque with a peak of 260?
man, a 4.0 ford or 4.3 gm would fit that bill better then a 300. but an efi 300 might run forever where a 4.3 definitely has an expiration date.
pcollins
7
Middle of Nowhere, NY
GMC
4.8L
My cousin has a blazer with a 4.3...Had a bent valve when he bought it, got that fixed. Then on the way to Pennsylvania it threw a rod on him. Had to replace the whole engine. I'd take a 4.0 over a 4.3 for sure.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
bent valve.....yeah.
the 4.3 is fatter and flatter then a 4.0 in torque and really out powers it a good bit....
if you bought a 4.0 with a bent or burned valves i am sure it would die soon after as well.
4.0 is a bolt in though...so its a winner:icon_thumby:
