2wd Off-road?
59Edsel
South Lyon, Michigan
153 ci
235/75/R16
Hey guys I've been thinking on something. Wondering if the experts could help.
I drive 98 Ranger 2.5L 5-speed, 2wd.
Other than the oversized tires on her, She stands taller than other Rangers. Not the 4wd's, they're about the same height. (Or at least it seems like it :rolleyes:)
What the question is this:
Did Ford make 2wd off road 4 banger Rangers? I've got a pic here that shows my current ride (with oversized tires) with the bumper sitting 1 inch away from the frame.
Now I've been looking to lower the truck to a 2/3 height but going down 2", you'll see my problem.
Now the truck has 212,xxx miles on her so could the springs have settled and I need new ones? Seeking advise from those who know more than I.
-Grant
rusty ol ranger
2.9 Mafia-Don
7,756
Michigan
177 CID
No "off road" 2wd ranger ever built.
Except the "edge" which were all 3.0
59Edsel
153 ci
235/75/R16
Ok. mine's a XLT.
next question. Do bigger bearings help for off road?
As I said I've been looking into lowering the truck. Everybody (or at least mostly) everybody puts Mustang rims on their truck for the street appeal.
I've got a set of rims from a '08 Mustang V6 and they wont fit due to the center hole not being big enough to clear the bearing on the hubs. So am I missing something?
I measured my current rims and they have a clearance hole sized to about 3 1/4".
rusty ol ranger
2.9 Mafia-Don
7,756
Michigan
177 CID
Ok. mine's a XLT.
Bearing size does nothing for off road ability.
Im guessing that youll need older (pre 04) stang wheels to fit your ranger. I had a set of 01 mustang wheels on my 99 crown vic, which, also would fit ranger rims.
59Edsel
153 ci
235/75/R16
Would you know if I could swap spindles to a newer, something like a 2011 set up?
Too difficult, Or to many changes?
Ranger850
Doesn't get Sarcasm . . .
4,703
Tallahassee Florida
Stock 2"
Stock
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,619
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
They did also have a package that was called the "Trail Head". But I believe those 3.0's with torsion bar front.
Go2fasteddie
Yep!, was thinking the same thing. Lol.
Uncle Gump
Token Old Guy
13,619
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I actually wanted one of those... just couldn't get a 4.0L.
pjtoledo
3,017
Toledo Ohio
Fords
3.0 2.3
the coil spring spindles from 1998 to 2011 are identical.
your coils may have sagged slightly, my 2005 had about 1 or 1.5 inches at the bumpstop when new.
check for "drop spindles", be sure to specify coil springs.
59Edsel
153 ci
235/75/R16
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Off topic but by your name, do you actually have a 59 edsel?
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,871
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
The closest thing to an off road Ranger from the factory was the Edge with the torsion bar front suspension. Theoretically, one could use one of those with a rear locker as an off roader and do ok as long as one doesn't get too crazy. It would never do everything a properly set up 4X4 will.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
My 93 s-10 2wd with a small lift and a locker was a beast on sand trails. Traction and ground clearance are the main 2 things you want offroad. A 2wd with a good locker and a lift is better than a stock 4x4 with open diffs. At least in basic trail scenarios. A transfer case with a low range is awesome on rocks/hills though...
59Edsel
153 ci
235/75/R16
Yes. Although I should change it to 58Ranger. I own a 58 Edsel Ranger, and 59 Corsair.
No members online now.
