Rich 2957
- Mar 30, 2020
- Reaction score
- 0
- Location
- Pasadena md
- Make / Model
- Ford ranger
- Automatic
What is the torque recommendation for the front brakes
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
The nut that holds the bearing inSlider bolts or bracket bolts?
Yes RWDI take it you have a rear wheel drive then? Someone will come along with the info on the spindle nut torque. I think it’s torque to a certain speck while seating the bearings then back off to a lesser torque but it’s been a long time since I worked on a RWD.
Thank you ?The spindle bearing? Preload while spinning the rotor till the rotor has some decent resistance, then back off completely and tighten to 12 INCH pounds not FOOT pounds. Specific preload torque is arbitrary since the races are already seated. You just wanna insure the rotor is seated on the spindle then set the spindle nut torque.
