2010 ford ranger front brakes
Rich 2957
Pasadena md
Ford ranger
What is the torque recommendation for the front brakes
sgtsandman
Aircraft Fuel Tank Diver
12,584
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Slider bolts or bracket bolts?
Rich 2957
Pasadena md
Ford ranger
The nut that goes on from the outside
sgtsandman
12,584
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
I take it you have a rear wheel drive then? Someone will come along with the info on the spindle nut torque. I think it’s torque to a certain speck while seating the bearings then back off to a lesser torque but it’s been a long time since I worked on a RWD.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
The spindle bearing? Preload while spinning the rotor till the rotor has some decent resistance, then back off completely and tighten to 12 INCH pounds not FOOT pounds. Specific preload torque is arbitrary since the races are already seated. You just wanna insure the rotor is seated on the spindle then set the spindle nut torque.
Rich 2957
Pasadena md
Ford ranger
Yes RWD
Rich 2957
Pasadena md
Ford ranger
Thank you ?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Check for play when your done. If necessary you can go up to 22 inch pounds. The old school trick is to tighten by hand as much as possible then 1/16th a turn more using a wrench.
