2005 honda accord help!
scott5640
5
Davenport FL
i read a code on the car for
P0457 EVAP Emission Control System Leak:Cap Loose/Off
where is the cap located?
and what can i do to fix it
backroad101
4
4.0L OHV
Code PO-457: Evaporative emission (EVAP) system, leak detected or fuel cap loose or missing.
Did you recently get gas? Did you tighten the cap properly? Did you top off the tank after the pump clicked off? After reading the code, did you clear it? If so, did it come back? Is the car running poorly?
Yeah, gas cap.
