2005 ford ranger 4.0 ticking at idle… fixed
RedRanger05
Peoria Illinois
Ford ranger
I have a 2005 ford ranger with the 4.0 I have just over 200k. It’s started making a ticking sound recently. it’s usually at idle and most of the time it’s a quiet tick. recently I was sitting at idle in park and it was much louder than usual. I know these engines have noisy valve trains and I am well aware of the timing issues. Can anyone point me in the right direction for what’s causing the sound.
franklin2
1,758
Virginia
Is a 2005 SOHC? If it is, you know what the problem most likely is.
rusty ol ranger
2.9 Mafia-Don
7,494
Michigan
177 CID
Get a mechanic stethoscope and start probeing. Its probably timing chain tensioners.
Or possibly exhaust manifolds leaking...but probably option 1
RedRanger05
Peoria Illinois
Ford ranger
The sound was most prominent right in front of the exhaust manifold on the driver side
Uncle Gump
Token Old Guy
13,459
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
IMHO... the 4.0L SOHC doesn't really have what I would call a noisy valve train.
From where you say the noise is coming from... it could very well be timing chain noise. Pull the driver side valve cover and have a look.
RedRanger05
Peoria Illinois
Ford ranger
I had it off a few months ago to replace the valve cover gasket and everything looked good and the chain was tight. I put a mechanics stethoscope up to it and it sounded more like it was coming from the spark plug.
Uncle Gump
Token Old Guy
13,459
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Well... at 200K it's hard to tell.
Have you changed the tensioners?
The oil pan comes off pretty easy. The amount of nylon trash in the pan will tell you the story.
RedRanger05
Peoria Illinois
Ford ranger
I have not changed the tensioners. I am thinking about doing that as well as plugs before I jump to timing issues. I had the pan off when I did the valve cover gaskets and it was clean.
RedRanger05
Peoria Illinois
Ford ranger
The sound turned out to be a spark plug. The gap was way off so I re gaped it and threw it back in till I get new plugs. Thanks for all the help and advice on the problem.
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
Good troubleshooting!
Still best to renew those 2 OilPressurized TimingTensioners every 80k~100kMiles, so you're 100kMiles overdue!
Likely a testament for a good habit of regular oil+filter changes.
RedRanger05
Peoria Illinois
Ford ranger
100% agree in the spring it’s getting a full tune up and that’s on my list. The oil change has been done in it every 3k miles when I had the valve cover off it looked mint.
