2003 SWB Ranger 2x to 4x conversion
Ruffinit
Muscatine, Iowa
4.0, 2.3 Duratec
Tell me this; I have a '03 Ranger with the 2.3 dohc/5spd. What would it take or is it possible to drop one of the front drive axles (given the ratio is the same) from my '88, '89 BII or '94 Exp under it? All three of them are complete vehicles.
I know that some of the 4x2 Rangers/BIIs don't have a crossmember that the 4x4s have. Is that still true on this generation?
lil_Blue_Ford
6,182
Butler, PA, USSA
4.9L
The 98+ Rangers have a totally different front suspension compared to the older trucks that you have. I'm sure it would be possible to do the front suspension from an older one, but it's gonna take a TON of fab work to do.
ati190
Pennsylvania
351
If it's a sport, or an edge you would only need to add whats missing, IIRC.
pjtoledo
2,980
Toledo Ohio
Fords
3.0 2.3
the 2wd front coil spring trucks have different frames, no EASY way to do 4WD conversions on them.
Fx4wannabe01
February 2010 OTOTM Winner
20
Boring, Oregon
^^x2.
Solid axle it on the existing frame. OR...front half or swap frames with a 4x4 98+ with the same cab/bed config(or get a 2wd torsion bar frame then do the conversion. Only one bracket needs welded to he frame, everything else is bolt-on. Go manual tcase.).
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
IF (and that's a BIG "if") you have a torsion bar front suspension, look at THIS LINK. Notice how he had to disassemble his entire transmission. Even though you have a manual trans, you still need to disassemble it completely to swap the output shaft. It would be easier to swap out your transmission for a 4wd one, but Ford never made the 2.3 Duratec with 4wd, so you're stuck with disassembling the one you have.
Now, if you have a coil spring suspension, you'd be better off either swapping frames, or doing an SAS. And you'd still need to take apart your trans.
Ruffinit
Muscatine, Iowa
4.0, 2.3 Duratec
Bummer.. I was hoping that this was going to be a simple swap, but wasn't sure about the twin axle fronts.. Didn't realize that they used different frames on the 4x2 vs 4x4. My Ranger is in new condition, so I'm not willing to do the frame-off and was hoping to do it with a light budget. Ahh well, thanks for the info.
Ruffinit
Muscatine, Iowa
4.0, 2.3 Duratec
BTW, the truck is a regular cab step side like the original Splash.
Fx4wannabe01
20
Boring, Oregon
OP says 2.3L in the OP.....2.3's Duratec's are only found on coilspring 2wd's. Not torsion bar.
lil_Blue_Ford
6,182
Butler, PA, USSA
4.9L
yep, there is no simple or cheap way to do it with these newer trucks.
i did it with my choptop but BIIs use a 4x4 frame and trans on their 2wds
Fx4wannabe01
20
Boring, Oregon
correction...there is no simple or cheap way to do it with the OP's truck. Converting a Trailhead/Edge/Sport 2wd(torsion bar) to 4x4 is really almost a bolt in project and can be done for pretty cheap....only one bracket needs welded onto the frame.
