Holy cow! Did I ever bite off a project? Trying to get the turbo out today, so I'll be ready to replace Y casting on the back of it. I still haven't really figured out how to reach the passenger side up-pipe bolts. So far, I've removed the inner fender liner. Then I got the exhaust outlet pipe loose at both ends. But couldn't get it out of the way until I removed the transmission support cross-member. Once that was out, I got the bottom of the up-pipe loose and, since the packing at the top is blown out, I could slip the up-pipe out if the upper flange and remove it without loosening those bolts. I've got about 2 1/2 hrs of work time left today before I have to cleannup and go to an appointment. I should probably have removed the transmission. But that's something I would rather avoid.
Do I really have to put all this stuff back?
Inner fender liner
Tutbo exhaust outlet is right behind the lifting tab. The up-pipe flange is behind and below that.
There it is. Clamp and bolts still intact.
