2001 ranger 4.0 fuel pump circuit issue
Sq1
Raymond NE
I have a 2001 4.0. Truck ran and started fine. Now fuel pump doesn’t seem to be running. I swapped some relays and I tried a jumper on the two relay pins. Hasn’t helped. Is there anywhere I can easily check to ensure the fuel pump is getting voltage or does it require dropping the tank? Or any other ideas? Thanks
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,646
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Did you check the inertia switch behind the passenger side kick panel to see if it’s tripped?
Sq1
Raymond NE
I did check the inertia switch. It seems to be in the correct position.
