- Dec 25, 2022
- 6
- 90503
- Ford Ranger 4x4
Hi All,
I am slowly working through the general maintenance for a 2001 Ford Ranger XLT 4x4 I picked up with 63k original miles. It has the V6 4.0 SOHC engine and the 5R55E transmission. I am already planning to change the transmission fluid/gasket/filter, but have the following problems.
Once or so on my 30 mile commute to work (street and highway) the transmission struggles to shift from 3 to 4. If I apply throttle, it refuses to shift and the car stutters a bit/rpms will not increase. To get it to shift, I need to let off the throttle and then reapply it. It then shifts fine. I also read somewhere that I should put my car in man1, accelerate to 20 mph, and see how well it engine brakes. It appears to not engine break at all. Is this indicative of a bad valve body seal (I csn inspect and replace) or are there other parts I should consider replacing?
Best,
Matt G
Best,
Matt G
