2001 ford ranger bank 2 lean
joshuakaesekamp
California
ford ranger
3.0 v6 has code bank 2 lean runs fine no i high or low idle just replaced fuel pump because of slow start witch is now fixed. just wondering if anyone has any ideas or what could casue it. ive went over most vacum lines and they seem to all be fine and bolth exhaust gaskets are new if any one has any ideas or ways of trouble shooting it would be much appreciated thank you
8,372
Lean code on just one side of the engine is usually not a vacuum leak unless its a lower intake gasket leak
Anything in upper intake or MAF sensor would effect BOTH sides of a V6 engine
O2 sensors can only "see" Oxygen, not fuel, so "lean" means too much oxygen in the exhaust on that bank
O2 sensors only last 150k miles or 12 years then they start to show lean, they run out of chemicals
Lean code means computer is having to opening injectors on that side of the engine 15+% longer than it calculated and its consistently over 15% longer or it won't set the code
So could be a clogged injector on that side, try running some Seafoam, or similar injector cleaner in the gas tank
Misfires don't burn up any oxygen so that oxygen is dumped into exhaust manifold, so Lean
But you said it runs smooth, no misfires
Exhaust manifold can suck in oxygen if gasket is bad, so Lean, but you say they are new
Long shot is failing Cat converter used on that bank, if it has separate converters, they can break up inside and slow the exit of exhaust, which causes O2 to show lean
If MPG has gone down a bit then its most likely a "false lean", so computer is adding more fuel than needed, which would be O2 sensor, exhaust manifold leak, or clogged exhaust
joshuakaesekamp
California
ford ranger
thanks for your reply is there a way to test the o2 sensors to know if there broken or do you just have to replace them to find out if there broken. this truck has 181000 miles on it.
8,372
At that many miles I would replace both upstream O2s, just because MPG will improve for sure
At the cost of O2s they more than pay for themselves in fuel savings over the next 10 years
But yes you can swap the upstream O2s around, and if lean code moves to the other side then its that O2 that's failing
But the work to do that is usually more hassle than just replacing both, lol, especially at 180+k miles
joshuakaesekamp
California
ford ranger
okay thank you ill look into replacing thoes
joshuakaesekamp
California
ford ranger
so i replaced the upper intake gasket and both o2 sensors and that fixed the check engine light thank you for your help
8,372
Good stuff
Thanks for the update and THE FIX
