MarshSt
- Jan 30, 2011
- 0
I just joined the forum looking for info on this issue and have found a lot of good stuff here.
I'm helping a friend with a 2001 Ranger with the 4.0 V-6.
Just finished new head gaskets w/head rebuild for coolant leaks.
Started and ran fine after we were done but the oil pressure gauge spazzed out.
Found out about the idiot light/gauge thing and now have a mechanical hooked up to check oil pressure. I have no idea what the oil pressure was prior to working on this.
Oil pressure now is 25-30 psi at start and drops to 12psi at idle after a few minutes.
We already ran Seafoam at idle for 30 minutes with no real change except a few psi drop at initial start. I'm thinking that is the oil thinning from the seafoam.
What it does now is 25 psi at start and down to 12 psi at idle after a few minutes. Revving the engine to 2000 drops the pressure a couple psi but no knocking or lifter rattle.
We're suspecting a blocked pickup so we dumped the oil and have diesel in the pan trying to soak out the intake screen.
I hope that clears it up but I'm wondering if we are overlooking anything.
It sounds like the cam synchro may be able to cause oil pressure problems and I'm wondering if it could be slipping or if they only fail outright. Any ideas would be appreciated.
Thanks,
Steve
Thanks,
Steve
