2000 towing?
WilliamTell
Hi guys. Was just wondering if anyone knew the towing rating on a 2000 ranger with a 3.0 and auto transmission. I have looked around with mixed results. I just want to know what is the maximum SAFE weight someone might suggest i pull. Looking for a travel trailer and dont want to get too big for my truck... Taks for any info guys.
Mac
183
C. Wisconsin
2000
199
Well the manual shows 4120 lbs for a 3.73 gear4060 lbs for a 4.10 - this for a 4x2 reg cab. Super cab 3.73, 3920 lbs. Manual shows about the same for 4x4. Know others will say they've hauled heaver.
Dave
WilliamTell
Thanks man! My rig did not come with a manual when i bought it from an old man... I will look up howto find my gearbox etc. thak you again! You rock!
Gear box = transmission. You don't care about the trans so much as the axle ratio.
03xlEdge
California
I have an 03 Ranger with a 3.0L V6, 4:10 gear ratio. I tow a trailer that weighs about 1,000 lb load over a mountainous hwy with 8% grades. It handles perfectly fine. I feel that I could tow a lot more when on flat land.
Alan Gerrard
You can pull a load which you think, you can and depends on the road you if it is a straight road then can go up to maximum and if you need to climb a mountain then it should be an average weight.
