2000 Ignition Cylinder Problem
Underdog_jku
Law Enforcement
7
Ingleside, Tx
Was working on the truck and it starts up and shifts in and out of all gears fine. Goes into park, revers and drive with no problems.
the problem comes when I go to turn the key all the way back, turning off the vehicle and trying to get the key out. The ignition cylinder will not turn all the way to the off position in order to allow the key to be taken out.
there is not a switch on the side to allow it to turn like my ‘99 had either. The symptom is the same as if the vehicle were in drive and you turned the key off and it will not allow you to turn it all the way back. But this is doing it in park. I have taken the cylinder out and turned the key that way, but this leaves the vehicle in the on position and all accessories running.
Any ideas?
8,370
Is the steering wheel lock pin working, it needs to slide up and lock the steering wheel when you turn the key to OFF
Try moving the steering wheel a bit to see if that's the issue, it should be spring loaded so you can turn the key to OFF but maybe that's broken
Underdog_jku
Law Enforcement
7
Ingleside, Tx
The cylinder will not come back in order for the wheel to lock in place. It will not turn backward past the ACC position.
8,370
ACC - OFF/LOCK - RUN - START
But some years also did this
ACC - LOCK - OFF - RUN - START
So 5 positions
Those are the 4 or 5 position of ignition switch under the steering column and for the ignition cylinder rotation
Key can only be removed in the OFF or LOCK position if it has LOCK
Steering wheel pin moves up to lock the steering wheel when you turn key from RUN to OFF/LOCK, and steering wheel stays locked when you turn key from OFF/LOCK to ACC
Simplified diagram of whats inside the column: https://blazerforum.com/forum/attachments/full-size-k5-1969-1991-gmt415-1992-1994-tech-42/11046d1357121213-ignition-lock-issues-rod-issues-2012-03-08_031156_steeringcollum_diagram.jpg
Underdog_jku
Law Enforcement
7
Ingleside, Tx
Ok but none of this explains why the ignition will not return to the off position in order for me to pull the key out. I have tried every single thing I can think of to get it out short of just breaking the pins inside the ignition cylinder.
i have turned the steering wheel all over the place, and wiggled everything I can think of and nothing will allow it to turn backwards to the off position.
Underdog_jku
Law Enforcement
7
Ingleside, Tx
I’ll have to get a video of what it’s doing so it could easily be explained.
Underdog_jku
Law Enforcement
7
Ingleside, Tx
Here is a short video of what the problem is. Any ideas?
holyford86
Some guy with a problem
610
Plattsburgh, NY
many
33x12.50R15
try lifting up on the shifter (pushing it further into park) while turning the key towards the off position
Underdog_jku
Law Enforcement
7
Ingleside, Tx
Ok figured out what it was. Have parts enroute to fix it. The shifter tube and pin were not engaging the ignition clip to allow the ignition to turn all the way.
