fij
- Apr 7, 2024
- 0
- concord nc
- Ranger x.t
I've done a ton of work to bring this ranger back. Replaced head gasket, timing chain, water pump, spark plugs and bunch of interior stuff. I got it all back together. it start fine, coming up to speed is fine. but if the engine sits around 12-1500 RPM in any gear i get some odd engine vibration. It might be missing during this time but it seem like a bad vibration to be caused by missfire. I did have a pending code for misfire on cylinder 1. I'm going to check the spark plug later today but i expect it to be fine. I did have the harmonic balancer off for the timing chain change. could the harmonic balancer be going bad. i've heard coil packs go bad on these. i'm not getting a pending code anymore. I've cleaned MAF and IAC. I have a fuel filter i'll probably put in the next couple days. That was $8 so it just seemed prudent. I don't have problems getting up to speed with engine calculated load in the 80% so I wasn't to worried about fuel pressure or the injectors. next steps I was thinking was coild pack or harmonic balancer. coil pack is $25 and harmonic balancer is $65. I've heard some say the coild packs go bad so maybe its worth it to change it for the price. Anything else i'm missing?
