Uncle Gump
Token Old Guy
- Sep 17, 2018
- Reaction score
- 13,458
- Location
- Ottawa IL
- Make / Model
- Ranger/BroncoII
- Engine Size
- 4.0L SOHC/2.9L
- 2WD / 4WD
- 4WD
- My credo
- Lead follow or get out of my way
So I've done a little testing on my IAC. Key ON I could feel it "click" but it didn't appear to be doing its job. I pulled it and it wasn't plugged up solid but I spent a little time cleaning it and put it back on. Same thing... click but not working. So I pulled it back off and tried bench testing it. While it will activate with that audible click... the pintle really doesn't move. If it is moving it certainly isn't much (0.010-0.020 inch).
How much should the pintle move? My thoughts are that it should be more then it does.
I've looked up the Ford part number and got E3FZ-9F715-A... Which is no longer available. I didn't or couldn't find a superceded Ford number. But while searching for a Motorcrsft replacement... I'm having zero luck. I see that Motorcraft part number CX1823 is listed for the 2.9L from 88 through 91 but it says it doesn't fit my 86.
Am I missing something here? Will this CX1823 fit my 86? My gut says yes but just want to be sure. If anyone clean offer info... I sure would appreciate it.
