"2.9, Won't fire!"
djhitz
Fort Wayne, IN
2-1987's
Fords
2.9l V6
I recently found, my computer was for a 3.0l, Taurus or Sable. I have, the 2.9l computer on its way. I reinstalled, the distributor, ignition coil and EEC relay, cap, plugs, wires. Line'd the distributor with #1 plug and rotor to #1 on the cap and the TC line on the harmonic guage. It won't fire. Yes and I've been removing the spout wire every time. I've turned it back about a dozen times now. I switched the cap wire back one contact to see what that would do.
To start with, though. I accidently wired, the distrubutor 180 degrees it started warmed up and ran OK (as it ever did without the proper ECM). I test drove it. It sputterd, cut out and ran poorly with no power and to boot, I was in a place in traffic where I couldn't pull off (overconfident). So I had to drive it like that for a while. When I got back and shut it down, I started to set it up for rewiring the distrubutor and each time, I rewire it. There's still, no spark!
"Was tun Sie zum, mein, Colongne V6?
Wait, you put the plug wires on backwards and it ran. You put them on "right" and it quit.
I'd say they weren't wrong to begin with.
That far back I can see a 2.9 running on a 3.0 computer. Possibly even running properly. The computer system isn't that complex and the control circuits and components are pretty much the same. The ignition system is stand alone though. Aside from where a circuit gets interrupted by the PCM being absent the ignition system should function perfectly without it.
Your efforts to time the engine from scratch may meet with more success if you would line it up with the -10* mark instead.
djhitz
Fort Wayne, IN
2-1987's
Fords
2.9l V6
"Oops! Not -.10 but .10, 0 and TF."
Sound Man,
We only set the balancer at +.10, 0 and TF. Well try, -.10 tomorrow. Thank You."
Yeah you want it at 10* Before top dead, that's -10*. It should still fire at +10* but run terribly and have no power at all.
unoleisu
6
Stillwater, Okla
Hate to throw this question in but what "other" computers can work with our BII's? Just wondering, incase of an "emergency" situaution...It would be cool to have some kind of list of swappable parts.
Any 2.9 computer of the same year or later, trans, and air metering system will work. Different trans will work in a pinch.
In a severe emergency I can see a computer from a comparable year 3.0 or 3.8 working as well. It was the same ignition system and most of the rest should be close enough for Jazz. Might not run wonderfully, but I'd be money that you could at least drive it.
djhitz
Fort Wayne, IN
2-1987's
Fords
2.9l V6
"Wire Break."
"After seven weeks down, my B2 lives again. After the replacement of nearly all, the ignition parts. There was, no go. A wiring search revealed the, red wire coming from the distributor's, spout wire to, the EEC relay had been rubbing on the fender for, twenty five years. It was rubbed right through until just, a couple strands were left making contact. When just one strand was, left. No signal was getting to the ECM to turn on, the fuel system. The replacement and resolder of about, 2 inches of wire, brought everything back on. The old computer had to be used. A, full signal running throught this wire is sending, a full signal and with all the new, ignition parts. My, Bronco II runs better than ever. It should even get better gas mileage. I'd say. Thanks to all concerned:icon_cheers:. Success.:yahoo:
Let this be, a lesson to us all. Your vehicle problems aren't always obvious. Some trained, detective work might be needed.":icon_thumby:
B2 Addict
9
Lavergne, TN
Solid Axle Swap 4x4
37x12.50-17
Glad to hear ya got lil blue back on the road man! Since she's running better than ever now, I see a trip down south in your future! :headbang:
djhitz
Fort Wayne, IN
2-1987's
Fords
2.9l V6
"South!
:yahoo:"It'll happen as soon as, I can work out:icon_confused:, the details:D, B2 Addict.":headbang:
