Crashtest84
- Sep 6, 2007
- 0
- Tulsa, Ok
- ford
- Engine Size
- 4.0
Swap was a 89 2.9 to a 4.0 unknown engine yr but using 91 ecm and harness. first I will give you a lil laugh after getting the engine harness in place I put my old 2.9 ecm on it not knowing. Fought with it for about a day then checked. But it still doesn't run right with the 4.0 ecm. Its not firing on the 1,2and 4 cylinders. I have spark at the coil on all 6 and the wires test good. Tonight i replaced the plugs no change.
Things I have not checked fuel pressure, compression or any sensors as far as I know the CEL is not on but I might not have that wire hooked up. It has a new fuel filter and I have cleaned the mafs. I am sumped on why its the 1,2 and 4 cylinders
