2.9 to 4.0 radiator swap
Trevorrudai
Idaho
What years of 4.0 Ford explorers can I pull a radiator off of for a 2.9l ranger? Thanks
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
To 94 iirc
Trevorrudai
Idaho
I'm sorry what does iirc mean
Trevorrudai
Idaho
lvwill
143
Las Vegas Nv.
2.3 EcoBoost
2.3 Ecoboost
If I recall correctly
Trevorrudai
Idaho
Ok. Anybody able to confirm? A 2000 4.0 radiator wouldn't work?
Trevorrudai
Idaho
Also can anybody tell me what these lines are for? This is a radiator off of a 92 4.0 Ford explorer. My 86 ranger 2.9 does not have any of these hookups how can I go about using this radiator still are there plugs that I can use?
BlackBII
Ranger Custom
Truck of Month
982
UT
Those are the ports for the automatic transmission fluid cooler. With your truck being a manual, you don't need to worry about those.
Trevorrudai
Idaho
Okay so if I don't have to worry about them then that means I need to plug them correct? What would I plug those with
97RangerXLT
TRS 25th Anniversary
3,966
Fishers, IN
2"
31"
a bolt with the same threads would work fine.
AJ
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Needing a bigger rad on a 2.9 is typically a sign you have other stuff going wrong.
Last time you flushed AND back flushed the block?
Dirt that the factory left in the block = blown heads.
