My '90 also suffered from poor accelleration once warmed up. I had replaced the O2 sensor as it had given me that code, but what ended up clearing it all up (last Sunday!), was putting in rebuilt injectors. I got mine just two weeks ago, from
CS Performance Fuel Injectors (https://www.cspinjectors.com/).
It cost just under $60 delivered, for 6 rebuilt and flow-matched Bosch units, and they made a world of difference. Before, if I would push beyond say 2/3 throttle on a warm engine, it would just not respond but would actually sort of 'sink', and you could feel the ECM adjusting the settings 'back' as it was apparently being starved for fuel. Only if I floored it would it sort of pick up again. Now, it pulls strong all throughout the rev range and has become positively quick. If you don't know the state of your injectors, I would definitely recommend putting in a fresh set like I did. It may not be your issue, but it's an inexpensive measure that will probably help your engine in general anyway.
P.s. I also looked for a fusible link on mine and could not find it. I did replace the fuel pump relay and the ECU relay, underneath the fuses box, as these can also cause issues. Another relatively inexpensive and worthwhile measure. Good luck with the fix.
